If you're already locking up, increasing traction will help. Wider tyres.
Yeah, I forgot to mention that I had balding fail spec Nankang 215 tyres on some TTF 7" wide rims :D
But never fear, thanks to Hamish I have got those SSRs on the way. 8" front and 9" rear.
Should get a 245 on the back. That will definitely help.
... or just don't jump on the pedal so hard and pulse your braking.
costs $0, and it level up's your driving skills.
Well... It's only happened ONCE. And I learned my lesson. But the brakes still get to that "locking up" point too quickly. I can feel it.
Was pretty funny when I did it. Middle of Nepean Hwy in traffic. Made a big amount of smoke. People looked at me as if I was retarded.
Pretty embarrassing :D
woot. just bought a brand new unpainted OEM VW golf MK4 R32 kit.
now the question is, should I get the optional MK5 GTI style front bumper or should I get the regular MK4 R32 front bumper?
probably should just stick to MK4, cos putting a MK5 front is a lil wanky like R34 fronts on R32's. Mind you there's not that many guys no one who've done it.
huh? why are you searching for a front bumper when you have already bought a 'kit'?
i say go MK4 all over, that silver r32 with the black BBS rims looks porn
cos the kit can be supplied with an R32 front bar, or MK5 R32 style front bar. Same price, 100% polyurethane (no fibreglass), fits perfect etc. Gotta love aftermarket parts out of Europe... none of this half arsed stuff like jap aftermarket parts.
Yeah consensus seems to be that MK5 R32's should only exist on MK5's and not on MK4's. Pity no one's done it before (or if they have they've done some gaybo fibreglass conversion that looks shocking) so I can't tell if I like it or not.
so you have no idea what the mk5 front will look like on the mk4? sounds risky
nope. I know... that's what's shitting me... the fact that I can't visualise what it'd look like. Otherwise I'd have made the call and gone for it.
Pat spending money? I don't see that happening lol
On another note;
My engine fan has been replaced with a thermo fan due to the larger radiator.
Anyone know a good thermo fan controller? Im after one which reads ecu water temp signal, can set trigger point (85degrees) and will turn off when it reaches another set point. (80degrees)
Now go :D
You fan should run off a thermositor. Figure out if you can tap a frequency or voltage line coming out of it and then add one of these:
http://www.jaycar.com.au/productView.asp?ID=KC5378
http://www.jaycar.com.au/productView.asp?ID=KC5377
program in the relevant voltage/frequency that corresponds to the temp you want and off you go.
thanks for that, Found this;
http://autospeed.com.au/cms/title_Electron...77/article.html
Has a temp on and cut off. Although im not sure how to wire in that if AC is on that it is always on...
Any chance you know where the 12v Aircon trigger wire should connect on the relay?
Thanks
Same. f**king pissed myself when I got her messages and called her an idiot.
haha
poor guy didnt know what he got himself into
although ironic how many times she told everyone she hated greeks and yet shes with one now :thumbsup:
want me to exchange some eggy gifts? :nyaanyaa:
haha nah man all good
as much as i hate her, i just thought it was f**ken hilarious :)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
