With any track oriented car, the idea is to have proper cooling.
I see... how often do you get on the track then? and no, motorkhana days doing one lap wonders don't count. When was the last sprint or enduro race you entered? Cos a radiator that size is only ever gonna be of use when you have massive heat soak to dissipate. You're running a thrmo fan with no shroud on a street driven car, which will result in pisspoor airflow through the fins in stop start low speed driving.
It's true, I hardpark my daily... ever since I got 3 dents in my daily at deca i refuse to track em. That's why I have a perfectly good stripped out, rollcaged race car sitting at driftline for when I got out to winton etc (running a triple core koyo rad and a couple of thermo fans off some ford)... which is for sale btw, as I won't have a shop to maintain it or time to race it.
What I'm getting at is that making a daily driver into a "track ready" car is an expensive, uncomfortable process. You'd be better off just buying a cheap second car and going balls out on making it an all out track car. Your car's emo enough as it is, the more you push it, the more things are gonna break.
</ethug>
</ethug>
fyi I was meant to have a track day this saturday but pulled out due to car problems and no one said that my cooling setup has been finished. Twin thermo setup + shroud (AU falcon) is the next step, depending on the clearance. (else flex-a-lite low profile thermo setup)
I have a hyundai getz as a backup car, but i will continue to drive my car as a daily and not have it looking pretty in the garage. So all im saying is, dont assume what my car will be used for because it makes you look silly.
The r32 has always been aimed at being a track oriented car because in the future I will be buying new cars but this car will always be sticking around as its not worth selling.
/drunkl
just bought a jzx100 chaser :)
converted from nissan to toyota
dam i miss the 33 still
congrats
pics?
lol? how come. What did you wear to get in?
collared button up shirt
black jeans
wog tappers
we all got asked to leave though.
turns out for every underage person there, there had to be an 18 year old
so we all went to crown and shit
nah weather is absolute shithouse
drinking yourself to sleep would be more advisable
haha told
friday night was great
all day today was crap
had to unload the truck in the pouring rain. i think im sick now
just took car to brakes plus for 2 hours and they have managed to get rid of the brake squeel that the other 3 places ive had it at for long ammounts of time couldnt..
finally 8 months and no brake noise!
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
