yeah... and i think there is a XXX store around there or its where the XXX store used to be.
just go in there and ask for johnny.... if you tell him hamish sent ya then you'll get looked after :banana:
dunno bout you, but the 7m we had did 400,000km's without blowing a gasket. only reason it came out was cos my cuz went for a 1JZ swap. did blow an alternator, starter motor, and water pump tho. Just service it regularly and don't sit on the limiter all the time n she'll be fine.
The car was a hand me down from my old man, and then from me to my cousin. Who then wrote it off. Idiot.
You had a good one then. It's one thing they've been notorious for doing.
zomg... just like my cousins habibi's rears on da VN
i saw one of those horrible hyundai coupes, the rounded ones. it has interceptors with a polished lip and black centers
oh and that red thing is pretty sweet :)
should be in HPI soon... so i'm happy to let someone else pay :)
thats awesome!
well done on building a great car
i bet their intros gona be like
during the day, hamish hampton fries (insert foodstuff here) but during the night, he fries nothing but rubber bla bla etc etc
and is there a difference between HPI and PI? or is there just a name change?
Edited by GTR-boy
Guest
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
