20's rev higher than 25's, so they both have thier up's and down's
so say you hit full boost @ 3500 in a 25 and rev it out to 7000, that's pretty much the same as hitting full boost in a 20 @ 4500 and revving it out to 8000
i was thinking, how awesome would a 32taxi look with a GTR front
dumped on EQUIPS.. or advan Rs's
edit: where the f**k did i pull challenger from? 0.o
Edited by GTR-boy
my mate bought one... flash tune etc etc had a lil over 200 @ all 4's
he was bored with it in like 5 mins
i enjoy mine.... just want my new wheels farken :down:
Rb20's pull ?? Lol. I've driven a rb20 with a bigger turbo. Can make a cup of coffee before it spools. Worst engine in a skyline :cool: but it's strong
mine was actually pretty responsive with 225kw considering the size of turbo etc
just needs to be setup and tuned right
oh i see...
barley see any nice r32 sedans around..nicks was the nicest
in Adelaide now so we will never see it again :P
definately one of the best...
:rolleyes: i do miss it
aight. Thermo-fan controller is wired in! Wiring a bit ghetto but should last me through Saturday's drag day so I can fix it up during Sunday. Just need to program the correct temperature signals and we good to go!
It cooled from 92 degrees to 80degrees in 8 seconds whilst standing still O_o
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
