RPM = (SPEED / 28) * 1000
it looks to ramp at 3900rpm
would be good for the street
Awesome, posted it mainly for you to see paul :)
It goes a lot better now, crazy when it comes on boost :)
Just gotta call me chaddy! Aint no problem haha
Aight, this is how im programming my thermofans
@ 80C: 1st Thermofan turns on and runs at 50% speed
@ 81C - 88C: 1x Thermofan speed increases 51% - 99%
@ 89C: 1st Thermofan at 100% speed + 2nd Thermofan at 100% speed
@ 86C: 1st Thermofan at 50% speed + 2nd Thermofan at 0% speed
@ 78C: 1st Thermofan at 0% speed
78C is a reasonable driving temperature with a 52mm radiator?
Yea i love the extra 30rwkw midrange! Who cares about the 300 now lol. Cant belive the cat was robbing me 30rwkw in the midrange. f**ked that thing off nicely lol
yeah they can get bad
chuck in some e85 and you get more power everywhere and crack the 300 :)
I get that on my stock radiator
ah yeah nice. I was getting 84deg on my stock radiator, hence why i replaced it. Used to be 80deg but slowly moved to 82deg and then 84deg. Most likely it was becoming full of crap.
Will trial 78deg driving temperature. Being Winter now, shouldnt be hard to maintain.
One thing im worried about is that my thermo-fan controller looks like an aftermarket ecu. Hopefully the cops will believe me when I tell him its a fan controller as it doesnt even say its a fan controller on it! haha
yep 80deg is ideal operating temp
the powerfc and presumably stock ECU are in correction mode until water temp is 80deg bang on
that is, it adjusts the timing and richens up ever so slightly until water temp hits 80deg
in my GTST i never get to 80deg, the problem is that annoying i had to remove the correction below 80deg
on my 33 temp correction is disabled when it reaches 50deg, as i found it would never get to 80deg bang on
so it would forever be in correction mode. now its fine and once 50deg is reached, no more correction
just chuck it into the glovebox
nah too much wiring to bring it into glovebox. Its mounted in the engine bay next to the battery.
interesting, the r32gtst retards/runs a rich map until 65deg, then switches over to the proper fuel map. So r33's bumped it up to 80deg?
Maybe you got a dud thermostat being open the whole time allowing the engine to not warm up?
In the morning, open the radiator cap and start the car. If you see water moving, then its cycling through the engine which it shouldnt be...
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
