they look nice but i cant see myself spending 4k for them though.
the tyres alone are worth over $1k easy, then brand new sp1s in that size it is a bargain when you think about it
but if you dont have the cash thats another thing haha
does anyone in here like to listen to classical music sometimes?
I did a few years ago when I was playing in an orchestra. Not much interest in it these days though..
phags :D
phags :D
haha, it shows class :D i have a folder of classical music that i sometimes listen to, it really helps you to chill and relax. ive got another folder with frank sinatra and dean martin lol. i like a huge range of music.
I only listen to it for study purposes :D Although there are a few classic pieces that are awesome. Like Orff's 'Carmina Burana'. EPIC.
http://www.youtube.com/watch?v=qF-Z0YPuabk
Edited by jezza boii
working on my car helps me to relax.... forget everything
i end up having my neighbours come over and say whats with all the yelling and swearing lol. and that's no joke its happened a couple times. one time i had the last bolt on the suspension that wouldnt come off i tried everything all it did was start to fall apart and i tried every trick, than after alot of yelling i grabbed the angle grinder and cut the Fu#ker off.
maybe ill listen to classical music next time im working on the car :D
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
