the way i got 35 is if you consider the rate of change for country x between yr2 and yr3. Rate of change being 2. Then by counting ahead of yr8 it will give you 35.
BUT!!!!
Question says rate of change of fossil fuel consumption by manufacturing not company x.
So the rate of change is 1 (total yr2 manufacturing fuel and yr3 manufacturing fuel, gives you 42 and 43, so 1 difference)
So that means 48tonnes for yr8 but then how do you split that into company x?
Or the answer could just be 35, i got nfi haha
2nd stage of job interview is doing these bullshit questions. They have a practice test on the website. Who knows how to solve this?
hahaha, the last place that tried to make me do that test before I got the job, I looked at the guy, told him "thank you for completely wasting my time" and got up to leave. he asked me why, and I told him where to jam it if he wanted me to jump through loops when they clearly needed someone with my skill.
so he made up a score and offered me an increased wage :blush: still turned down the job tho, got a better package from Penguin.
Not the same penguin Billy Madison see's when he is drunk is it?
ive had my 33 for 7 years now
it's done 23,000 each year since i got it
broken radiator
coilpacks died
alternator replaced
diff is grumpy
usual wear and tear - clutches, tyres
37% more power than stock and held up pretty well considering
what sort of job funkymunky? and that's a fair effort to call someone's bluff like that, im guessing you were feeling particularly confident lol
web development, I'm guessing its the same thing Pat's goin for but a more junior role?
Guest
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
