My car is fine :P I only thought it was broken because these stupid wheel alignment people told me it was.
Hmm.. Going to order coilovers now.
BC BR Series - $1300 NEW
or
Tein Flex - $1100 USED
ive searched the BC's for the evo on evoOz and a lot of guys are running them as entry level coilovers for track and for just normal street driving
and all really good feedback from them
i actually rode in an evo 7 last saturday that my mate was looking at buying that had the BC's 8k front and 6k rear springs and with the damper turned down it was like driving a normal car, couldnt even tell it had coilovers
it was even less stiff than my standard shocks with tein s-tech springs, but then you can adjust it to be really stiff
what wheels did you get Anf? those work ones you linked?
yeah they are wed kranze ERM's
damn dirty though!
ill take a pic of one i spent about 3 hours cleaning last night and one i havent cleaned
need to buy some new rubber for them tho :D lol
taken on iphone so sorry bout quality
so much dirt and tar im guessing it is
how they started
after alot of elbow grease + a cleaning product called gumption which is some multi purpose cleaner (tried heaps of other things i have laying around and wouldnt get through any of the dirt even tried a tiny bit of degreaser on a tooth brush and didnt do a thing)
after a few hours
and how the front of them look
going to need to get the gutter rash fixed up but to be honest much nicer than the stockies :D
same spring rates as my monoflex
and i love the ride even know it can be very firm at times around the shit melbourne roads..
im guessing u had super streets cos they are
F : 4kg/mm
R : 4kg/mm
i cant even imagine what they would feel like driving around the shit roads say around toorak / prahran..
F : 4kg/mm
R : 4kg/mm
i run greddy 6/8 coils wound all the way up around that area every day....
niggas jus need to man up!
Guest
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
