his xd9s where around a trillion times better..
I was wondering where you were... lol Not backwards at all! in fact im about 10 steps foward on all you suckers!
Let me ask you this. How many skylines now rock xd9's? Way too many!!
A few more pics, Same specs as what im after
damn i like your evo nick!
haha cheers bro
they look hot in fluro yellow though
black might be a bit too subtile in them
whats backwards bout em?
for starters no one staggers 17's and 18's anymore unless you're poor and enjoy rockin peasant status. 18's all around or 18's and 19's or GTFO.
Living under a rock or...?
Above rx7 for starters running staggered 17s n 18s. Running 18s n 19s would look ridiculous, the thought of getting 19s for my car makes me automatically think of Tempe tyres for some reason.
yeah i dunno why you'd stagger the diameter, i was talking about the wheel itself. one of my top 5 fav designs atm. LMGT4, 3pc Meisters, RPF1, RE30, equip, bbs meshies
haha yeh im a busy guy welcome back!
nah man those wheels are asss you can do wayyyyyyyyy better
Hey Leigh, i got the specs for the xd9's i posted a pic of yesterday:
its 18x10 with +18 offset, which i just saw was pretty much discussed on the previous page on the xd9 sizes you can get.
Cool cheers mate :blink: i ended up getting some 18x10 +15 black wheels which you guys will have to wait and see Nick is the only one that knows :thumbsup:
cool, cant wait to see what they are and how they will look on your car.
Cool cheers mate :D i ended up getting some 18x10 +15 black wheels which you guys will have to wait and see Nick is the only one that knows :blink:
:thumbsup:
all i will say is hottttttttt :D
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
