don't BC's come with 7kg and 4kg springs standard? From memory that's around the same rebound rate as stock. Performance gain? Turn the dampening off full firm and see how the bounce rate is. The midrange of most cheap coils are terrible, they only work properly at either extreme due to the nature of their valving. Add to this that BC's don't have progressive springs, and it's pretty much a recipe for fail.
With the same amount of money you could get a very good set of matched springs and struts that will last longer, perform consistently and much more smoothly. Fuck adjustable dampening and height, the only guys who do that usually have $5000 suspensions and visit a suspension shop before and after each event. If someone's on a $1200 budget for suspension their broke ass isn't gonna see a suspension shop after it's been set. ever. they'll just ghetto it up at home every time they get defected.
in which case you'd rag on him for not dragging his balls low enough on the ground (or whatever analogy it is you like to use)
so what's a kid to do?
save up and buy decent coils so he can do both?
not that he'd ever drag his balls too low to the ground, he'd destroy that fibreglass kit of his at the sight of a bump in the road... so he'll be running it at a safe and possibly legal height, so why bother with cheap coilovers?
All i know is my BCs feel good :) and heard good things from suspension specialists, and the reason why my car isn't balls slammed to the floor is becuase of:
1. The area I live in.
2. My dad spent a fair bit of time repairing my front lip while I was doing other things, and would hate to screw up his hard work of repairing it properly
BC coilovers are actually pretty good shan, they are pretty much rebadged greddy's. Spring rates 8 / 4
pigs arse, we've fitted about 3 sets on cars, and they were almost identical to the other equivalent stuff from race logic and G4/D2. Just powdercoated a different colour. Shit we even showed the race logic guy who looked after our trade account and he was like "ummm yeahhhh funny that".
8/4? you had better spring rates when you were rockin superior stock suspension for acceleration.
running 10/8 on the GTS4 on matched Tanabe springs and shocks. Is nice. Bumpy, but not as bad as my old 12/10 setup which was bumpy as fuck, but it's not a daily so I don't really give a toss... and if the passengers don't like it... they can GTFO and walk.
Guest
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
