THURSDAY NIGHT STEAK NIGHT
who's in?
also watch for reference and familiarise yourselves with appropriate greeting...
dont tell me you expect to greet us like that in the meet..are you? lol
I'd like this comment stricken from the record. 2 stars at best.
you really didnt like the movie? i thought it was funny...a lot of people did...what was wrong in it?..like to know..didnt hear a negative comment about it yet and cant wait...so go nuts...
It had some funny moments, definitely wouldn't call it a good movie though...a few chuckles were all I could manage..
you must be hard man to please...lol...nah..the funny moments were the lameness of the situation...not that the situation was funny...thats where i think the movie wasnt as good but did think it was worth the watch...
most of the funny bits in that movie were in the trailers so you tend to expect alot more funny stuff when you go see it but you dont really, just the same bits you already saw in the trailers.
Sunshine cinemas are good... But local does the job for a weeknight sesh
except your car is likely to NOT be there after the movie..
i thought other guys was funny, stupid but funny.
good night shiela.
its worth seeing for eva mendez lets be honest.
where at?
Thursday Night.
I'd love to say Squires Loft, but then nga's are gonna whine about $30 for a steak.
How about the Royson in Richmond? They do $15 steak n chips on Thursday night specials. Good steak too. Somewhat central to peeps too.
http://www.roystonhotel.com.au/Thursdays_Steak_Night
good night shiela.
it got 1 star for her having her tits half out...
and no one is going to steal my car...it's just not worth it lol
Thursday Night.
Ah f**k, working thursday night...$15 decent steak sounds good though, might have to sus it out sometime
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
