decent steak doesn't come under $30
yes, but ngas here would rather spend money on mods than eat properly.
anyways... event thrad created...
http://www.skylinesaustralia.com/forums/St...ht-t336845.html
Have to agree on the most part for that, although there are a few exceptions.
What I hate is when someone orders an expensive steak, and they want it cooked well done. HOW THE f**k ARE YOU SUPPOSED TO SAVOUR THE FLAVOUR MAf**kA?
if peeps are willing to pay extra then we should def go to Squires Loft for steak.
and yeah, medium rare max, any more and you can GTFO n take your salad eatin bitches with you.
depends on the cut of the steak and the marbling of said cut...
e.g. whereas a lean eye fillet would be best eaten rare/med rare, a heavily marbled wagyu scotch would be better cooked to medium.
if meat has a lot of fat, said fat needs to melt before the steak will be at its prime.
also if there is blood running all over the plate it means the chef is shithouse/lazy/justacook... even a rare shouldn't bleed when done properly
hey guys - long time no login - whats crackin!
What up!
WTF have you been?
Tuff kent!
Love that S13!
Wish I could go that low, only problem is I'd make it 100m from my house before hitting a speed hump!
yeh.... i can only just make it into my driveway as it is...
looking to get some steel so it's not so bad, then i'll go an inch lower :(
man your joint is like prison double speed humps or go around the park but that street is sooo farken bumpy its not funny.
tripple fail.
Have you tucked your cable/wires into your front quarter panel? I destroyed a few of mine lol mine are cable tied up but that's not gonna be good enough when I get my new wheels! I'm going lower!!!! :(
tripple fail.
Yer that's probably my fault, crashed my mums integra just after that corner cos I wasn't looking and some old bitch had parked her car on the road right after the corner... Lol
mine are just cabletied out of the way...
i havent hit any of them yet.... but i might have to relocate them when i go lower :(
spose i'll just take the FQP off and shove them inside :(
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
