I need to relocate my cable in teh cef, it wore through a few at first and random shit would happen like headlights go on when i turn the car off or horn when I lock the car.
relocated it a little higher and cable tied the crap out of it, but it's only a matter of time before I hit a hump at speed and the wheel grinds at it.
lol i chained a few cable ties using existing holes in the inner guard to make this spiderweb like thing which pulls the cables up as high as possible.
it's a work of art really. so proud of it.
Like when you go to your little brother to tech him how to be a total bro, and he responds "but you've been passively teaching me my entire life, bro" as your girlfriend walks out of his room. And you then fist-bump in recognition of how proud you are of him.
think i might resign.. this place is too stressful and crazy now days FFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU~
not to mention about 20 people were made redundant recently and emails are going around saying please dont use the colour printer, clearly they are broke
hahaha...your work place is not the only one...i know a lot of poeple who have been shown the door after working years for the place...no respect for the hard working old employees....
people that worked longer then me got the sac.. i guess it comes down to performance and availability.. but its just ridiculous here now you cant even follow up on things without getting told to do something else while your taking 2 minutes to write a email.. so ghey and the management is fail.
anyone got any networking / system admin jobs going at there workplace :D
I got a raise and I hired a new designer for my team. does that count?
also new crackberry should be good. not the bold tho, that's shit. I'd still take the Galaxy S over both... but make sure you get the non AMOLED version, cos the amoled screen is bright but blurry.
No one gets fired from my work. Unless you steal there is nothing they can do lol
that cause all the pissheads keep you in business LOL
ended up getting the Galaxy Ric, charging atm so cant play with it yet :D
edit: how do i know if its the AMOLED version?
Edited by GTS-T_Sedan
i thought 'AMOLED' was the sweet screen that's making everyone furiously fist themselves?
until they stopped and compared it to other screens of the same res and went "WTF is this shit?"
same phone... different screen:
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
