lol at the skinny jeans the fag is wearing
haha skinny jeans are 100% fag... 0 to douchebag in 0.1 seconds
oks
350z to is250?
jah...
AWW..suck it up princess...i do 7 days 8 hr days..now less surfin net...more working..chop chop.. :P
that's 56 hours a week.... at the moment i do that every week as an absolute minimum, and over christmas time i'll be adding another 20 to that
lol i start work sometime between 8:30 and 9:30 and finish around 6:30, although I usually leave work at about 8ish. Plus I've come in on the weekend to get shit done for the last two months.
mind you if i stopped being on SAU or ZT and reading blogs etc I'll probably cut an hour n a bit out of my workday.
HR sent me a quiet email askin me to take annual leave cos I've got like 5 weeks accrued, which I forwarded to the CEO with "hahaha I'm outta here". Got an email back going "not till the end of the year, we need you."
Fuckin end of year bonus better be 5 digits.
if i did that i wouldnt have a work day hahaha..
<3 my job..sometimes.
same on annual leave had 15 days off in 4 years.. they owe me a fair bit :P
I've got 9 weeks accrued - but there's no way I'll be able to take any til after we release later in the year
Our company policy is that we can't have longer than 4 weeks annual leave. If we do we gotta take it in chunks of 4 weeks... not like an epic break to go around the world or someshit.
Ours is that we should have no more than 6 I think except with manager approval - I have manager indifference
I have this too, but we have an HR department full of pregnant women that have massive mood swings.
fact that it's a S30 fastback makes it instantly better than any other car in this thread.
20mm spacers ordered. No more tucked in rears :P
great, now you're gonna be mexican. what happened to 10mm to 15mm?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
