great, now you're gonna be mexican. what happened to 10mm to 15mm?
I dunno.. lol.. I just wanted the rears to be wider than the fronts.
Solution? Epic camber? or flared guards?
20mm shouldn't be a big ask :P
lol tell that to whichever panel beater you get to do that.
you're that high off the ground that no matter what you do, it's gonna look like a bag of dicks. roll your lip and hope for the best.... at least that way you won't cut up your tyres when your springs compress.
i cant wait to finish.. gona go home and slam my face in pillow zzzzzzzzzzzzzzz, and by pillow i mean YOUR mothers boobs
on another note, G27 steering wheels are awesome :P
edit: why are all american modified imports always look so much better then us aussie / bogan spec? should go ship petette over there eh he might get stabbed
well ipretty much have sat at my desk trolling sau,vic,CL google etc.
ran out of things to look up been like this all week =\
same here, its gay cos alot of image hosting sites like imageshack photobucket etc get blocked, as well as facebook and those type of things makes it a bit boring..
no, there's just more of them, so there's a better chance of them doing it well. also their laws are kinda lax and you don't generally get into trouble unless you're packin drugs or driving like a dick.
if you wanna see the amount of dickbaggery by kids with no clue, check out:
http://240sxfamily.com
Facebook.com got blocked here.
Then I started using m.facebook. That got blocked.
Then I used touch.facebook, lite.facebook etc. until they all got blocked.
These days the only one that isn't blocked is pirate Facebook :P en-pi.facebook.com
Only problem is you have to remove the www and replace it with en-pi everytime you go to a new page.
true that makes sense, forgot about there population
I can bypass the proxy server, which means i can get onto what ever site i want but then i'll just get in trouble so not worth it anyways i sometimes just use this method for a picture i really want to see or something not sitting on facebook at work or anything
AGREED!!! works always boring here....days goes very slowly..and then you work 7 days..it becomes a PAIN!!!!!!!!
Why do you work so much man?
I'd rather get less money and have more free time. If you're not out enjoying life then what's the point?
:P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
