Why do you work so much man?
I'd rather get less money and have more free time. If you're not out enjoying life then what's the point?
HAHAHA!!! I enjoy dont you worry.. :P ...and sif i work hard when i am at work...i am more on this forum than actually trying to work...so getting money to sit around and do nothing...i dont mind... :P
I can bypass the proxy server, which means i can get onto what ever site i want but then i'll just get in trouble so not worth it anyways i sometimes just use this method for a picture i really want to see or something not sitting on facebook at work or anything
How do you bypass the proxy server? Other than the obvious option of using proxy sites.
Get off the f**king facebook and do some work :P
But atleast it keeps you "busy" during the day...
Eh... I make my boss MILLIONS. I think I'm entitled to a little bit of entertainment to keep me sane while I maintain a database of over 50,000 clients and add a further 200+ a day :P
i bet you have been on it ten times by now anyway....YOU GET TO WORK YOU LAZY BUM!!! LOL!!! :P
How you do that? easy to do?
Well my workstation computer has XP (like most would) and has restrictions for my user account obviously and the internet browser runs through a proxy setting ie. proxy.internal.xxx.net.au on port 8080 which your company sets up and blocks sites such as facebook so when your accessing facebook with your computer its like "nah dude you cant do this at work category: social networking or what ever"
All I do is just login with remote desktop to our database server and use the browser there.. has no need for proxy settings in it at all and have complete access like you would at home
YOUR A NERD GENIUS!!!!!!!!!!
Hmm.. Seeing as I love black but can't afford a full respray - what about half and half?
I'm thinking black roof, bootlid and spoiler...
Boot/spoiler like this: http://i101.photobucket.com/albums/m79/gre...R2/P1000798.jpg
Roof like this: http://i723.photobucket.com/albums/ww231/grk801/IMG_0010.jpg
My car just got resprayed in red about a year ago :P And I wouldn't mind doing the whole exterior again... Just don't wanna pay for engine out, door jams etc...
Edited by jezza boii
bah sent a letter to EPA requesting a warning due to being on business trip for the past 3 weeks. Just got a letter saying, they wont fine me but still need to clear EPA :D
Guess i'll be trailing the car up to motorkhana this weekend and then deal with the whole epa hassles :dry:
Anyone got a factory r32 airbox, factory r32 catback and factory ecu they willing to sell/lend me?
Thanks
Ouch pat. I got done for a defect. Hopefully no EPA follows :s
no goods. I got driver dynamics track day on 16th October. So have to restore everything to stock, clear the epa and put everything back on in 3 weeks! zzz
lol, I know, jspec sold the one I was looking at!!!! :dry: (I knew the site being down was bad luck!) I sent them an email with my preference and the next time one comes up I think I'll grab it. Then I'll get a tow bar. And pull my loves on the back. lol. WEEEEEEEEEEEEEEEEEEEEE!!!!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
