Would Blaqs be the next wheel whore from Abu :)
I've got:
4x BBS RS 16",
4x Watanabe RS-8's,
10x Work Meister S1's (6x 100PCD + 4x 114.3PCD),
8x Nissan Stockies (R33/S14),
4x Godfather VIP's,
4x SSR Vienna Dish II's,
6x R32 GTR Wheels and
2x R32 GTSt Wheels and
4x some factory VW alloys that came on teh Golf. :)
FFFUUU didn't realise I had so much junk. Does someone wanna sell my shit for me? I'll give you a 30% cut of the profit.
That 180 is gay. No different to r33 conversions on a prelude
lol it's the same colour as the strawberry 180sx I built in 1999. Honda Electric Blue.
I've got:
4x BBS RS 16",
4x Watanabe RS-8's,
4x Godfather VIP's,
Are you a garbage collector?
Ill take the 32GTR Wheels off your hands!!
lol it's cos all my wheels are at the workshop, so I just store them in a corner and forget about em. Up until 5 mins ago I didn't even try and figure out what I had.
$600 and it's yours. comes with 225 bridgestones.
I never offered cash, I offered to take them off your hands lol haha
Fuck you meng.
Ok so im now looking for front & rear camber arms... Should I go Cusco or should I go for the cheapies?
ikeya formula.
actually I got ISC's on my 32, and they're actually quite decent. Met up with the guys when I was in QLD, and they're an awesome bunch.
I love wheels!! If they come in 5x114 ill be rocking them soon haha they are cheap as chips too
Haha!
I've got:
4x BBS RS 16",
4x Watanabe RS-8's,
4x Godfather VIP's,
Damn!
So your the wheel whore! :)
You have Watanabe RS-8's and WORK Meister S1!!
I wanted a set for my Rolla, then I was thinking Superlites, then I went MA61's cuz I preferred a thicker spoke wheel.
Or should have asked you about the WORK Meisters S1.
I can keep note of you wheel list and ask around or if ppl I ask I can let them know.
ikeya formula.
why ikeya formula?
Well the question should have been, should I go for Jap stuff or buy Local/cheapies? because in terms of prices I was quoted around $400+ for the rear for Cusco or ~$180 for Local stuff. Now other options are kazama, ikeya formula, silk road, etc! I actually havnt checked if they make them for the front.
House to myself for 2 weeks... I feel like I should be taking advantage of this but I can't think of how :)
i noe...PARTY AT YOUR HOUSE!!! lol...how else...or just go clubbing and pick up girls and just bring them back to your joint for some action...man plenty of ideas out there to enjoy your 2 week freedom...LOL!! :)
I have a girlfriend so that kinda takes the fun out of both of those ideas :)
I've got:
4x BBS RS 16",
4x Watanabe RS-8's,
4x Godfather VIP's,
damn man.
I have started my wheel whoring but im still a biggener with a new wheel ever month lol.
one day ill have a shed full of wheels LOL
ill sell your shit shan if you want :)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
