parties???? BBQs.....
Shit yeah... Would be mad to have a BBQ with some car people.
Shoulda seen my house last year (parents go away every September). I had half the street lined with imports. Then Ian (UNR3AL) started his R34 at 5 in the morning and woke my neighbors. I never heard the end of that one....
HAHAHA!!! i hear about it all day long from my neighbours too...they hate it if i come late with my gtr on a weekday nit...weekends i got pardoned from... :)
jizzy. leave your house for 2 weeks, rent it out to holiday makers, crash with the gf. Use the rent money to buy proper fitting wheels.
Haha dude I wish. Could make a killing off this >$1mil house.
Unfortunately neighbors are watching over me. Anything suspicious and they'll tell my parents :)
trust you to make profit out of any situations...lol...great idea though.
^^ This
Unfortunately neighbors are watching over me. Anything suspicious and they'll tell my parents :P
Who they think you are?
Some kid who needs a baby sitter?
Nah, they're just really nosy. My parents got called multiple times last time coz I had loud music playing etc..
HATE THOSE NEIGHBOURS!!! at my mates house we cant even stand and talk (soft talking) in front of his house...they crack it hard and once they even called the cops...it was just them being fussy...and cops told us guys to leave and told them not to be TOO FUSSY!!! :P that was funny to hear from a coppa...
FFFUUUU~ got asked at work to move my car further back so the trucks dont side swipe it.. i'm sorry but maybe if they trimmed the garden there once in a while we could reverse in further..
I think they meant... "stop being a princess and parking your new toy a meter from the kerb fagnuts."
Wasnt kerb parking was in a actual space, just when you reverse in you can only go so far back becuase there is a building / bush that you back into.. sif i cant kerb park ive owned 3 33s
whos going to deca in nov?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
