nawww he just got the googlin skills if he had the hook ups
plus she's in the US. I just asked the guy who works on her car for moar pics. he gave me pics of wheels instead of pics of her. fail.
HAHAHA!!! you got good enough skills though...lol...better than what i would...cant find info i am looking for ever...takes me ages...lol..
Where would one take another to go on a 'hip date' now days?
It's been a while, but yeh getting back into it.. the ol' ball n chain..
depends on what your intentions are and what kind of girl she is really. Also, no one says "hip dates" any more. when was the last time you tried to impress a girl? the 70's?
bahahaha nah man we just seeing where things are going.. shes a smart girl so don't want to screw things up :O
Ice cream on lygon, then Eureka Skydeck. Guaranteed date win.
Sounds like a good idea actually, maybe save it for a more warm night
take her where you like to hang out usually:
1) it'll make you more comfortable, being in a familiar place
2) it'll give her a good impression of what kind of person you really are
3) if you're a regular, you can pretend to be popular
if you hang out in your mum's basement on the regular, then you're shit outta luck.
I guess that makes sense, These tips can be passed down to virgin-boy as well :P (oh his username is changed again :laugh:)
Maybe when he buys his 32 GTST he will get some action :huh::O
jk.. jk..
Will mount buller have any snow when the cruise goes up?
none in sight last time. i remember driving up there in nothing but shorts during some stages.
HAX!
lolnoob
applying for a job as a train driver... yes you heard right... and they do random piss testing during the application process
good moneys in that man. my cuz (full lebspec - 20's on his gtt. half german/lankan so looks it too) started out driving a few years back and now is one of three dudes that operate the main controls on sydney's entire rail network. he showed me his work - looks like the control room from pelham 123 (denzel/travolta mov) but only 3 dudes allowed in.
i'd give her some poke, roll her lips and then slam her. then flushhhhhhh. car is good too
you sir, fail at modifying cars, pleasuring womens, and euphemisms. all of it. you're doin it wrong.
jk.. jk..
i found that getting a friend to hold them down works well.
dididoitright?
Guest
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
