thought id do this modifying thing properly and instead of just getting power i decided to make my suspension better, i just bought a bunch of nolathane bushes, nearly there whole catalogue for the gtr. cant wait to see what it feels like when its all fitted :)
lol slow at replying
Ice cream on lygon, then Eureka Skydeck. Guaranteed date win.
Yeah date win
bahahaha nah man we just seeing where things are going.. shes a smart girl so don't want to screw things up :)
Sounds like a good idea actually, maybe save it for a more warm night
nah no need for a warm night.... i always get ice-cream with missus down lygon the gas heaters they have along there keep you warm while you eat
This is true :)
Hurt much?
A little bit.. 1st session for the outline took 2 hours which hurt a fair bit especially on my ribs then the other 3 sessions were only an hour. Last session was the top part which I thought was gonna hurt like hell again but I couldn't feel it.. I was more relaxed I think cause I knew it was gonna be finished :laugh:
shan how would 17x9x+20 go on an R32 taxi?
thankss, lots of love, xoxo.
(change my name back kunt :) )
lol that would need some serious flaring and camber to get right. Will be scrub central on the front.
17x9 +30 is the ideal setup for r32 gtst's.
thats what nisskid recomended with stock guards and low.. any chance sedans are different?
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
