Yeah, my gf was showing me. She made me stand on one leg and hold the band in my hand. I think it made my balance better. But then I tried again with other objects in my hand. Same effect.
I'd say it could be a placebo.
Edited by jezza boii
LOL!
Yeah it's bullshit.
*spends money on other random shit*
so like whos getting wasted tonight? 2.5 more hours of work. f**k yeh.
I gotta take a huge dump, gotta hold off till 5 when the sales girls go home LOL
If I were you I'd have told my gf that cupping my balls gently would give me better balance.
im back bitchessss
Well after repairing my front lip, I had a massive f**k off scrape going very slow mind you, down the village multi lvl carpark @ knox and to my suprise the front lip is completely 100% fine ! wooo :D
edit: virgin boy imo just get 33 GTR rims theyre cheap because you will probably write the car off anyway (not bagging your driving or anything it just happens a LOT, hell I did as well just be careful in wet weather and road camber it can fark you up if your tyres are getting bald in the insides.)
lol yeah, i can see that happening too :blink:
280 feels slow mate. And was out with a 2 350rwkw r34 gtts. One andru and the other bas. Bas has 356rwkw on stock engine with 3540. Wow and stock looking engine bay too. My goal is to get most power possible with internal gate and keep the engine bay looking stock
Guest
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
