lol unless its a friday forget it i work every day lols.
needa swap back to my stock front guards better fitment but doin it after winton
You just want full bad as poke for your wheels yeah...
Haha!
So much easier to work on an EVO engine then a RB cuz there is so much room.
+ Your oil filter is easier to get to.
But having said that, if you know what your doing, you can get around it in the RB.
both engines have there advantages/disadvantages
although service on the evo piece of piss compared to the 32 even with the hicas pump removed
oil filter is a max 2min job, its arms reach underneath the car
Say whaa, nuh this one is in werribee
And says your choice or a Lancer Evolution 7 or a Subaru WRX
mmmm is it like rallyschool.com.au? or something
there was a guy advertising on evo forums for it once
yeh basically just dropping the lower seat lower (in my case winding it down), would have got me lower, but i would have ridden on the bump stops and given me no travel, this way ive done it has lowered the car, but has actually given me back my stroke, and complete control over it simply by adding in spacers to drop the bump stop to a point where it is bottoming out.
i actually dropped my car a while ago and after a certain point, winding down my coilovers didnt actually lower the car anymore, because the car was sitting on bump stops, not the coils lol. wasnt THAT low either.
haha nothing wrong riding on bump-stops :)
Will look into making some up! cheers for the help.
Went to watch my friend do the rally drive. He did a half day course and drove wrx's and evo's.
The trick to rallying is that you steer into the corner and accelerate as opposed to counter steering in drifting. So you pull the front of the car through the corner and the rear slides out. They'll explain it at the beginning.
So you gonna ban'em like what you did with Virgin Boy for the shit talk you cannot stand..?
funny thing is i wasnt shit talking lmao
what does the E infront of HNR mean on the build plate. awd?
the first E stands for the emissions standard it complied to. All the early ones met that emissions standards (till 91 I think) got an E.
the rest:
http://www.skylinesaustralia.com/forums/R3...tio-t38809.html
lol I think you'll find that's the difference in steering an AWD vs steering a RWD into a corner.
the rest:
yeah i know hence why i stated it. Not everyone realises the obvious esp when never driven an awd car before.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
