And heres another for you boys - a little old but still good.
Check out the dish on the light green S13, and how many sets of rims he has
http://vimeo.com/10050812
And just because we all wish this car was ours:
lol we;; he forgot to charge me for the fuel pump so im cool with that
bahaha... fail
that being said, i need to find myself another shop to take the car to. i wish trent still did mechanical stuff
:D
Contact Femno. I can SMS u his number if u want (if I still got ur number). Him or his dad do the work. Honest. Do good work and don't charge an arm and a leg.
think i might get matty to put in my oil cooler
What am I the SAU pirate? :D
Fark I should just bring my PC on next apple peel.
you're the one who admitted to having 11ty terrabytes of porn and no social skills.
I really want a 370.. such gorgeous lines. I keep seeing P platers in my area driving them. Damn rich kents..
370's aren't that exy, compared to say an M3. It's probably the only Fairlady other than a s30 fastback that I'd happily pay silly amounts for.
you only need to hard wire it running walbros that are flow rated at 15v
in the skyline it will get around 12v from the standard setup which is fine for a bosch pump or stock pump
you will gain zero by doing a hard wire. i woudlnt do it (if i was ray), just takes time which will end up costing you more for zero gain
if you put a wallbro in there and were peaking 240rwkw then yes hardwire if you insisted on wallbro, but otherwise get a real pump - ie save cost and safety
:D s30's....
i saw a red 370. was dumped on its arse on what looked like black BBS LMs
was in st albans if it helps lol
errr.... why?
i need to heel toe because i run a HHHDB clutch that bites like a bitch unless the revs are matched
that was a joke.
i drove a mate's (stock) 350z last night... once you go HHHDB, you never go back!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
