Alex is to scared/to much of a fag that's why he went with the wide front guards. f**kn wheels f**king japan f**kety f**k f**k fcuk ahhh
:D
both engines have there advantages/disadvantages
although service on the evo piece of piss compared to the 32 even with the hicas pump removed
oil filter is a max 2min job, its arms reach underneath the car
True that man!
you're the one who admitted to having 11ty terrabytes of porn and no social skills.
370's aren't that exy, compared to say an M3. It's probably the only Fairlady other than a s30 fastback that I'd happily pay silly amounts for.
al... check out sammy from tyrepower hawthorne's 370
i'll grab photo next time i'm there
They only look good with a Power House Amuse kit on.
S30 WINS!
speaking of which when you gonna buy some rims for the taxi? and what are you going with?
im gona work some more and buy something good. maybe same rims as billy or meshies
i can already see myself dumping excessive amounts of money into it
How about I personally tell the popo you are driving a P-plate restricted car, and show them the way to your house...
they already know who i am and where i live...
you only need to hard wire it running walbros that are flow rated at 15v
in the skyline it will get around 12v from the standard setup which is fine for a bosch pump or stock pump
you will gain zero by doing a hard wire. i woudlnt do it (if i was ray), just takes time which will end up costing you more for zero gain
if you put a wallbro in there and were peaking 240rwkw then yes hardwire if you insisted on wallbro, but otherwise get a real pump - ie save cost and safety
what do you mean by real pump? nismo or tomei drop ins are a little out of my budget atm. the 040 seems to be doing the job. if i was gonna hardwire it, i'd do it myself over a weekend or something. cant b too hard
Is Bayswater too far for you?
chasers?
I was wondering what this shit about hardwiring was, scared the crap out of me at the thought I'd have to reinstall with direct feed. So just to clarify, an 040 running off the standard fuel pump wires should be completely fine for xxx amount of power?
The only issue I have now is when I "touch" the accelerator, say cruising around a carpark looking for a space, I hear a slight vibrating sound (would deadening fix this? Pump is secured pretty well to the cradle). Nut when idling without touching the throttle, or when driving I can't hear anything.
yes by real pump i mean non-walbro
you said 040 and thats fine a good model, it should give you around 260rwkw safely and easily
ive got a GTR one in mine and thats fine also, either is OK as long as its not wallbro
no need to hardwire, hardwiring the pump is bandaid for poor pump flow at normal 12v in the skyline
GTST has two stage pump control, low run and high run
when you tap the throttle the high run circuit runs and you can hear the pump more
drive around and watch ETC, SENSOR SW CHECK
youll see FP1 blip when you tap the throttle
driven an R34 GTR, and a 370z. I'd take the 370Z over the GTR anyday. Handles better, feels more comfortable, and more modern. 34 GTR's 10 years old now anyways.
Altho, R34 VSpec II or NUR I might take over a 370Z.
You WILL take a NUR over a 370Z :mad:
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
