chasers?
Nah, the mechanic opposite my work who does all of my cars now. Honest, knowledgable, reliable and cheap. Not giving his name out publically though as they're a two person shop and already have plenty of customers to keep them busy. PM me if you want the contact details.
It doesn't take a lot of effort to find something unroadworthy/illegal on a skyline. Your restriction is just another headache ontop haha.
i know, its quick enough for me at the moment, loving how east and effortless it is to drive.
im also very surprised with the condition of it, the floormats are still in excellent condition! lmao
also found this inside it.. what is it?
of course, you were meant to do that before you bought it
correct, put it in my mums name lol
lol, he wont listen to anyone his like me when I was that age, I was a fraction away from buying a 32 GTST but good thing I didn't the first week of owning the N/A got pulled over and checked for turbo etc.
All the best with it Mohsen, if you get f**ked by cops just buy another car straight away.. keep the 32 in the garage for 4 years. Then it will only be a 25 year old car :down:
thanks dude, hopefully i dont get any hassles, its not like i drive like a manyak or anything.
im not gona drive it on far untill i get an exemption too.
edit:
kinda what i want my car to gradually look like, minus guards
Edited by Mohsen
Looks like a 0-100km/h & 0-400m timer. Records how long it takes you to achieve either one.
no, i need to get my p's first
Why? I don't remember any part of the rules saying you have to be on your P's to ask them if the car is legal or not.
i actually rang them and asked them. they said i have to have my p's before they allow it.
finished the stupid logbook, just have to book them and go for the test.
also, shan, would you know where the valet switch is
in the boot...
i read somewhere theres a little lever for when you want to open the boot with a key or the pulley thing.
the pulley thing wont work and someone said its the valet switch/lever. DOING MY HEAD IN
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
