Would be hilarious to see an Arab / Asian / Jew / Indian to do business with each other... :(
THAT WOULD BE THE WORST COMBO!!!
Indian - too cheap to invest
Arab - smart enough to scam
Asian - wouldnt give you a bargain
Jew - well not sure what they known for.
ive dealt with jews, indians and asians
for me, arabs are the worst by far( they think just because we speak the same language im gona get on my knees and blow them while giving them a 60% discount)
indians- you get your cheap ones that want something for nothing and you get the ones that will actually spend some coin and get something good.
asians: not bad, complain alot sometimes
jews- all good, they come to buy, not to look and bust my balls and then buy lol
^^ This.
But you come across the good ones of all kinds so it not too bad.
My mate said the same thing about us....he said he has been proven wrong that all indians are cheap and never want to spend money...i replied and said which indian you know has spend some decent money around you...he looks at me and cracks up laughing...i didnt get it until he replied...YOU!!!
man living here i dont consider myself as a typical indian...weird... :(
Yeah, you ain't that cheap...
But I still won't give you a good price.
TYPICAL ASIAN!!! :)
but hey they are better friends than indians man...i have asain/arab/wogs/aussies friends but indian ones i have are the worst in the list...
indians- you get your cheap ones that want something for nothing and you get the lankans that will actually spend some coin and get something good.
fixed for accuracy :(
Mind you lankans want top dollar for everything they sell, and convince you somehow that it's the right thing to do.
TYPICAL ASIAN!!! :(
It good price for you... You buy now!
Most ppl I hang out with are white and some have Asian / Indian blood in them.
A friend of mine looks white but is 1/4 Indian.
Same with my other friend who is 1/4 Philipino, but looks white.
True..some lankans i know spend like no tommorrow and always buy the best stuff...they are good people in general too...some though ruin the reputation of others...hate when that happens...
its good to want to strive for the best.
my friends asked me why i havnt "choppd da springs n slammed it"
i said: cz i want to do it properly
they just look at you funny thinking wtf
then they move on to the rims.. "cuzz lets go to de tyre faktry in thomo, all de thomo hoons go there i cn hook u up bro"
me: nah, im allright.
HAHAHA!!! sounds like i have been in that exact situation... :(
would be so much spit flying round that convo
indians- you get your cheap ones that want something for nothing and you get the Singhalese that will actually spend some coin and get something good.
re-fixed. Tamils are dodgy as f**k. Just sayin.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
