I think I'm the whitest person in this thread. I burn the minute I walk outside.
That must be horrible :) I'm naturally pretty white in winter but in summer I end up extremely brown and very rarely burn :D
i used to work with an indian he was a top bloke. but they arent very good at driving taxi's or having a conversation with, everyone ive had in a taxi doesnt say a word. also why do they get lost all the time when they have a gps?
im an aussie and sold my gtr and bought a holden ute that has a huge 7 litre v8 that pushes out an amazing number of 350hp even though most euro v8's are smaller and make alot more. than i decided to add some huge antanas mainly for looks also some truck style sideskirts and mudflaps and just cut the exhaust off. than i walked into a bottle shop and bought me a whole bunch of stickers for my car, it looks tops now. i sold all my t-shirts and now only own blue singlets and dirty jeans. now ive got the true aussie accent and talk like ive never been educated.
in conclusion i hate country people, the end.
I fail at being an aussie. I dislike AFL, drive an import, listen to rnb instead of ACDC and would prefer a nice salad or sushi over a meat pie. Lucky our country is so multicultural thesedays :D
no, you actually fail at been straight.
homo.
Pie is good in many variants :D
myself I'm second generation, Dutch and Italian. Raised mostly Dutch styles though. Best quote by Dutchman at winter olympics. "were all about having a good time, we don't care who wins. As long as it's not the Germans"
Mmmm i would like to contest that title. I burned on Friday while working outside. My neck and arms are red as anything now. p.s i am NOT a ginger.
Prefer salad or sushi to a pie? You must be gay lol
Have a pie! What flavor? PIIEEE flavor
depends on the pie.... i hat eall the big manufactures ones like 4&20 and that
the best pies are the bakery homemade ones etc
otherwise its sushi > pie
This.
See Nick, we actually appreciate this thing called quality.
Just like I'll take a nice imported beer over VB or Carlton Draught.
best cheapest place to get XD9's?
thinking of going 17x9.5+17 f and 18x10+18 r in matte black on the 33 and throwing the professors on the celsior
(the celsior that i am "mohsen'ing" about)
Streeter, but expect to wait a while. Otherwise local, nobody, they are all expensive.
Hmmm interesting you going staggered? I was getting paid out a while ago when I ordered my wheels staggered. Do it! Will look good
so ive been looking at front pipes for my car and when looking at the top brands some come with a flexi pipe in it while others dont, is it important to have it or doesnt it really matter?
Was told it's ideal to have flexi pipe so the front pipe won't cause welds to crack.
Also, how do I get rid of the white writing thing on windows? Left the number since DECA and I'd like to remove it...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
