Whats happenin Jamie, Havent seen you in a while.
It was about 2 weeks ago at Garage Cafe :)
Just working and taking it easy.
Hey you still looking around for ppl to fix your rear bushings or whatever needs done?
My friend owns JAK Motorsport (Former as Drift Line)
Jack from Chasers works there now and he can probably quote you up on a price to fix.
Yeah gotta catch up soon.
yeah Oettinger 500ml cans are about all I drink these days, $42 for a slab, can't go wrong! (esp when CUB slabs are $48 fkn dollars!) $35 for slabs of most German beers at the Liquorlands / Woolies around here too, its great!
Boags is vile man, forced myself to drink a slab of it last cup day, shitful.
hame thats a fair intake of alcohol mate. might wanna watch that
/medical brain
everyone loves corona yes, but you gotta use lime. lemon is for wimmin. others that are on my regular list are asahi, beez neez, little creatures pale and golden, james squire, becks, bluetongue (white rabbit is pretty similar to this too), heineken, boags. guiness goes down a treat too
i try to drink something new as often as possible. dont drink spirits as much nowadays but partial to a bit of CC and Hennessy. can not even smell vodka after a certain incident a couple of years back lol
on tap at Shou Sumiyaki was the best :)
*Free
fucken tightarsed maso's :)
the mechanic from driftline Monty works at chasers now.
divided. I should go to Jak cos well, it's the old stomping ground, but then Monty knows his shit, and Kamikaze's on my side of town. decisions. decisions.
boags is ok in light form, heavy is horrible
cascade is good, light or heavy
vb horrible period.
carlton draught, not bad, a light form would be goooood
carlton cold, good as a heavy
tooyeys (however its spelt) extra dry = my fav heavy beer
tooyeys one with the lime, pretty farken good to for a heavy
dont like corona
tooyeys red, good for a cheap heavy
Mate ofmineis dropping a tt engine into his na poopra thru JAK. I was recommendind driftline to him recently. No idea that they're the same joint now.
Where's kamikaze?
Where's kamikaze?
lol yeah sold up the business, jak still pays rent tho :P they also paid for the shittonne of spare parts we had in there.
Where's kamikaze?
Is your mates Supra that, off colour Bronze / Titanium Grey 1 with the body kit?
It was about 2 weeks ago at Garage Cafe :P
Hmm yeh still need new subframe bushes but i've been saving to get the corona on the road which should be happenin this/next week if everything goes well :rofl: then I'll put the GTR away for a while till i get more money to fix it up.
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
