Sell my car because it has a problem? How about I just fix the problem. That would be the logical solution :devil:
If everyone sold their car everytime something went wrong there would be alot of f*cked cars on the market!
lololol fix the bent chassis hey? we used to do that at driftline on a rig using manufacturer alignment spec. minimum $9000 bill :devil: gotta take all the panels and glass off, bend the car till it's straight then put it all back on... or cut sections of the chassis out, sandwich in replacement section, then get it engineered.
the quote was in regards to your faith in people who spin stories and how naive you insist on being when people are trying to advise you otherwise. There's only so many times you can try to tell someone before you just facepalm and walk away.
do you honestly think there aren't?
depending on which part of the chassis is bent (I'm guessing front?) you might have to ditch and run before you sink any more money into that car.
fuck off... you know he's gonna do better than the majority of 33 owners :(
:devil:
we'll just publicly shame and humiliate him until HESDOINITRIGHT. So in fact, Mohsen didn't buy an R32, VIC wasteland just did.
pity it's auto. although, 11ty billion times easier to swap to stagea RB25 tho.
haha, yeah. gets a bit boring to drive around after a bit. kind of over it already, being auto n shit
Jezza, fkn sell it. Would you be comfortable running around in something thats got/had a bent chasis?
I know i wouldnt.
Fkn cost cutting indie wanna be ferrari driving wannabe rockstar ladyboys these days
Edited by Mohsen
mine :D
let go of the wheel and its dead straight, no vibrations no nothing :)
also took all the boot trim out in an effort to work out where the valet lever is- saw nothing suspicious
say valet switch again mutha fucker! i dare you... i double dare you!
lol man you should read the aussie VW forums, the fags on there get butthurt about anything that's not OEM when it comes to modding your car. it's a fuckin golf, get over it.
f**king this.
yer but lets be serious, 99% of the time golf owners are douches, gays or women
and sometimes this.
I know i wouldnt.
It's perfectly safe. Every mechanic has told me that. They couldn't even tell that the chassis was bent. It was the old owner that told me that.
Lol, don't worry, I didn't pay $10k for it :)
I got it so freakin cheap considering it has the GEN3 engine. My other mate was going to sell me his for $16,000! And then he blew the motor :D Lucky I didn't buy that one ay..
dont stress about it jesse. every car has had a hit at some point etc so as long as it drives straight etc and theres no issues who cares
no matter what you post theres always 2 pages of stupid feedback so take it with a grain of salt
but it is friday so its all good
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
