im not sure i agreed? i spent 2k on mine and ive used it every day since ive had the car, so ive had mine for 7 years and the stereo still goes good. some people really enjoy their music and it sounds reasonable to me if thats what he wants, he can reuse it later etc ?
i want one of those navara all in one units in my car, but its got an alpine head unit and speakers all round. so i guess ill put that 600 bux into something else.. like rimmmmmmmsssss :D
Meh all I got now is a pioneer headunit. Took out my 2 x 12 inch kickers and amp ages ago. They just gathering dust ATM
dam...i wud have bought them off you...lol...just bought 2x12 pioneer subs with amp off a guy...lol...cant wait to instal in my gtr...yay finally i can enjoy music in that car too...lol..
I have accrued my $4k system over the past few cars I've owned. It's nothing spectacular. Most of that money is in the $2.5k GPS/DVD headunit, which I got for really cheap after having 2 cheaper units which failed.
I spend a lot of time driving each week. I would go insane without good music :D I am a musician afterall. My life revolves around music. Cars will always come second.
Edited by jezza boii
projector is mounted and all is good
hasnt fallen down haha
one of those cheap $25 ebay china projector ceiling mounts
some of the finish was pretty ordinary, thread not straight etc
i cant imagine a china plenum etc copy where its critical to be clean, straight etc
Man this is getting wierd.
I live on a 16th floor apartment on St Kilda Rd, and in the past two days I have spotted two tiny skinks.
I hope they didn't migrate in my luggage coming back from Perth. Maybe I should check :D
make a terrarium and adopt em
A what?
The missus will freak out if she finds the second one :D
My only thoughts is they climbed up the outside wall and got in through the ceiling cavity (bathroom fan vents air outside to the balcony)
their going to tie you up, rape you and then rob you.
their crafty little f**kers
anyway
i think im in trouble.. girl im seeing wants to go formal with me but i commited to my mates that pre drinks, no bitches, limmo
so i told her i cant go with her lol
anyway
you fkn idiot...
Do you ever want even the opportunity to get laid?
i'm all for bros before hoes, but if you're seeing her, and if it's just drinks with your mates, then you should be making an exception. you can have drinks with them whenever, you can only go to a formal with her once.... unless she or you are retarded enough to repeat the grade. which is totally possible.
in other news, bought some factory Xenons for the golf from japan.
secondhand price from US/UK/Europe: $1500 - $2000 due to VW modders' version of takumi tax
secondhand price from JP: $500 shipped :blush:
love it, these muppets on VW forums are sooo wrapped up in their little ebay and forum world they just don't seem to think outside the square.
Guest
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
