probably a mock up :(
i've only ever seen 1 on the road. bout 5 years ago lol
sti > evo :ninja:
pffft your opinion fails :)
lol. in other news i got my new bushes for the gtr, also my new metal cat arrived from boost bitz, it looks really good and at a good price also aussie made, now all i need is the front pipe to finish it off.
we spoke about this..... straight pipe remember?
Pffftttt evo shits on sti!!!
bad :D
pffft your opinion fails :D
bad :(
im caveing in to peer pressure lol. the problem is my exhaust tip doesnt stick out from the back so all it will do is make a mess on the back and burn that lovely paint.
black/carbon exhaust shield will help a bit :(
briefly owned a Evo 6 Tommy Makkinen and it was a blast to drive. drove one of the evo 7 we imported for a mate and it was disappointing compared, even with the extra yaw control... drove a evo 8 rs and it was balls out fun, but i'd never use it off a track cos its just a rally car shell.
after evo 6 the only good evo is a stripped out race evo. 7 upwards just try to do too much.
yup, stick a nice resin coated piece of cloth next to a pipe that's hot and occasionally shoots flames.
you're a fuckin genius.
aluminium sheeting to protect bumper and rivets to hold it on. kgo.
once the resin is dried its going be the same effect as having the bar there
if its going to catch fire its going to catch fire (bar or the exhaust shield)
considering the showie nature of his car doubt he going to pop rivet into his rear bar
yeah i wouldnt pop rivet ill probably cable tie it on lol.
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
