you should own a regular car before you take on the headaches of a classic.
put it this way, this car's gonna be driven hard once a week. if it breaks it'll go into a workshop while I drive a daily. you, on the other hand don't have that luxury.
i got my parents cars in case something breaks..
anyway, off to sus out my spark plugs and coils again
dude its not hard to suss out what the problem is. Start the car, let it idle. Go to your coilpacks. Unplug the coilpack connector. Change of sound? If not plug back in, and continue through the 6. If there is no change of sound then that coilpack is farked. Replace it, end.
If it doesnt turn out to be the coilpacks, then look towards the injectors. See if any of the plugs has come loose. If it aint the injectors or sparkplugs, it could be the ignition module (the black thing ontop of the cover you remove at back of engine)
the only difference between when you got the car and it running like ass was your brilliant stroke of genius to "reset the ECU". what did you do to reset the ECU?
do NOT do the "tape the coilpacks mod"
i did that, car drove fine for a day or 2 then whenever i put my foot down hard car went nowhere...literally
took out coilpacks and the tape had melted loose and was all over the place
stupidity on my behalf but meh live and learn.
resetting ecu (disconnecting negative terminal for a day) is fine, ive done it heaps of times with no probs.
are you sure you havent unplugged anything and forgotten about it? or any loose clamps etc?
go over your engine bay and check all hoses/plugs etc carefully
just my 1.98cents
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
