most S14's do nothing for me, but I spotted one one the way to school a few weeks back that looked sick...had gay plates 'DAGURU' but the car itself looked the goods...still not a fan of the rear of them but the rest was tasty...Was the dark purple-ish color with some fat TE37's
if anyones got any decent photos of it post em up
yes mohsen, thats the joke. thanks guy.
lol
fail
lol
edit: going cq tonight. anyone frequent that place?
also, are the trim pieces where the tweeters go on r32s, the ones behind the side mirrors, the same in coupes and sedans?
Edited by Mohsen
s14 on 7 series wheels. a reverse funky
For some reason i actually think its looks pretty good...surprised with the guy who done it and pulled it off as a decent lookn car...
I want roof racks for me gtr :D
ok ill buy front pipes first than ecu later on down the track :D
:P
You shall be happy with it!
does anyone else agree the chick from scrubs is hot?
You talking about Elliot Reid and Carla Espinosa..?
anyone got a photo of JDM145?
A S15 with a S14 front?
any spoked wheel with slight concave on an s14 with rails on the floor will look good. bros in oz just don't have the testicular fortitude to rock it.
instead they homo it up by putting cheap shitty URAS kits on their cars and think they're instant drift superstars.
guys in japan have been putting Infiniti FX 4WD wheels on 350z's, skylines and silvias for the last 3 years or so. 19" or 20" + same PCD + perfect fitment for an OEM finish. combined with low it's instant win.
Where do i find it? is it in Sport or Entertainment? Im excited, should be good!!
i think the channel starts in november.
with my new cat that i got it has the sensor hole, should i block it before i install it or doesnt it really matter?
yayyy... got my tax return.
time to drop some cash on 240z mods out of the US while it's cheap as shit
http://www.arizonazcar.com/TRACK-PAK.html
by the time I'm done with this car it'd be the metaphorical equivalent of climbing up on the table and taking a massive dump in australian zed owners' cornflakes.
also...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
