ye, well I'm not about to go and buy 2 more TE37s just for the sake of offset, though I think I'm going to have a problem when my ATTESSA is working again with having staggered fitment anyway blah
You should be fine!
why not? once you have jap rims, then secondhand jap rims are a freeforall... just sell 'em for the same price as the next set you are buying
if you're using spacers, make sure you get the washers on them to stop them moving around and they won't mess your wheel balance up. if possible get ones with hub bolts, they're "safer" than just slip on's and don't move around at all, but you'd need a 15mm+ spacer for that, which might be too much.
but yeah, nothing beats choosing the right wheels with the right offset.
too much effort haha, yeah I'd never use slip ons, an R33 here had a wheel fall off due to having fark all thread and having the wheel nuts come off LOLZ.
Here's a pic to show fitment as it is currently :
Rear looks decent and could go more low!
your talking about slip on spaces hubcentrics bolt on to ur existing hub and give u 5 new threads so you do not lose any thread and if his wheels fell off with hubcentrics then a retard tightened them.
deff need to sort out the front and slam that tractor. john deere reprezent!
yeah, rear is fine. front needs a little more out... 15mm to 20mm? then roll the lip on the guards and drop it by just under an inch, should leave minimal gap, you don't have to run stretch tyres, shouldn't have scrapage on lock or over bumps... but it'll look tough. probably will get defected for height though cos the bottom lip of the front spoiler will drop under 10cm.
alternatively if you don't give a fuck, then do this:
18x9.5+15 front
18x10+20 rear
near perfect fitment for R32 narrowbodies. maximum wheel width, no fouling on suspension, and with a roll, no scraping.
alternatively if you don't give a f**k, then do this:
18x9.5+15 front
18x10+20 rear
thats AWESOME!
wheel sizes noted :stupid:
is that yours?
lol nah, mine's 6 different colours and runs stock GTR wheels atm... one day I'll get off my arse, fix the ABS system that's causing the front passenger side brake to permanently clamp on, and paint n panel it and throw on some wheels.
or I could sell it as is and drive the camaro when it gets here.
seriously cbf with the skyline atm.
18x9.5+15 front
18x10+20 rear
lol what size tyres are those?
Im running 17x9 +30 with 255/40's and no chance that will tuck under the guards with -0.5deg camber & rolled lip
hehe that does look sex, I like my ride height lol, no scraping on speedhumps or police attention for me! I actually like it that height, no scraping on speedhumps or police attention for me, and if I park too close to teh kerb, there's about 2mm of clearance to the front spoiler lol.
I would have thought that if I get the fronts to stick out further, that I'd have trouble with it fouling on full lock etc ^_~
As it is, the exhaust just clears 10cm, don't really have much fine adjustment re height, the coilovers are only circlip adjustable! More concerned with handling tbqh.
Guest
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
