haha im not trying to kill mine rimon, but it'd be funny if mohsen did his. when im ready to convert, i'll sell my gearbox and buy myself a mars bar with the money
believe it or not there are people who convert their manual to auto so you never know what your auto box is worth for the right buyer :)
is yours auto? :(
mmm.. i can really go for a mars bar
also- how can i go about making a police complaint re: harassment on fb?
just call them up n say ahh just wanna make a complaint?
yes its auto (semi :P) have thought of converting many times even went as far as buying complete conversion kit and then sold it shortly after. unless its a serious car (atleast a gtr or something) i dont mind if its auto or manual. auto's good enough for a daily.
lol i din know i was givin you that much shit on FB v-boy.
call em and tell em its about shan. that's all the details they'll need
ha. tru, but my chances of finding such a buyer are slim to none, considering that many more go auto -> man
lol...mohsen seems like you started complaining again...lol...worse than some girls...gezz man up :)
pretty serious shit.. would love to run in there and crack some skulls but family n shit
haha not you funky
Edited by Mohsen
Got my car back yesterday. Sooo f**kin loud!!! Full 3" exhaust, 3" hiflow cat, twin pipes, no mufflers or resonators just pure rb roar :verymad: makes me smile everytime I start it.
On another note. Added suspension bits now the car pulls left and right and feels all over the place. Apparently a wheel alignment will fix all of this, find out soon....
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
