Second hand Cartier watch from US - 6k
Second hand gcg highflow 1k
Nistune and dodgy tune 1k
Highflowed injectors + fuel pump + clutch 1k
2nd hand FMIC $ 200
Add e85, tune past the stock afm on ~25 psi
300rwkw and a Cartier watch all for the price of a new Cartier watch :P
Caution: will be a pig of a car, but you can have both :devil:
It's just that checking the time is a slightly more mundane exercise than going for a spirited drive in a high powered car
nb. i will probably still splurge on a nice watch when i graduate
ill too but not anymore than 1k....6k is just insane...got a armani watch atm myself...so like my watchs to a limit though... lol..
I have the costs of 300rwkw in the format of audio on a CD :P F*ck that sounds lame.
at least it gets you laid. :devil:
I'm all for watches, spend whatever you like. But that's an ugly f**king watch!!
I need a brown strapped white faced watch (the IWC is a black faced black strap and the PP is silver strap and face). Not a fan of the 18k gold around the face, I actually like the plain silver with brown strap Cartier, and I never wear gold jewelery so I'm still undecided. The non gold version is also like 1.5K cheaper. Gold one is signature series though, so holds its value a lot better.
Caution: will be a pig of a car, but you can have both :)
bought a s30 fastback :D no more dyno chasing, it's all about the vintage braaaap braaaap for me now.
This is the zorst I should be getting:
What you guys reckon? I think it sounds alright, considering 3S engines sound like aids normally.
Edited by jezza boii
bought a s30 fastback :P no more dyno chasing, it's all about the vintage braaaap braaaap for me now.
You mad!
Info / pics / what you want to do with it, etc...
Oh did you hear... That "Other" Zed...
wonder if the plates ZOMG are available... that would be sweet on an old Zed... hmmmmmm.
dunno just sent a deposit, waiting for it to get sent to the mechanic to go over it once again and replace any panels etc that might need work before it gets here (cos it'll probably be cheaper). Sold the GTR I got too. Good thing it was still at the shop waiting to get worked on.
I posted a link to the car on J-Spec a while back. It's the Midnight Wangan car.
Ah yeah that's right, the blue one.
You sold the R32 GTR already?
Did you even drive that? ;)
Egad! So sexual...
Hell yeah man!
FFFFFFFFFFFFFUUUUUUUUUUUU!
Damn Nostalgic Tax!
But if you had spare cash around, you'd pay it straight up.
lol no it hadn't even left japan yet.
Man, you don't fuck around that's for sure ;)
But I guess, the easy accessibility you have to high performance imports, you'd see so many of them, you get use to the high turn over...
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
