way to fk up a good mercedes
point of the pic was the rims, not the merc. i agree its ruined
HEKT1K although that looks good i wouldn't even do that to it. only way to improve a merc is with all black paint, black rims and a tiny brabus badge on the boot :(
haha yeh right not since i keep gettin warnings/bans LOL
plus im not against the advertising just the drop down form of it realllllllllllllllllllly effects my time on the forum.
LOL!
ok both pics are chops, but the car has potential. 1.6l turbo awd manual. goes for 13k GBP so should see around $25k here w options etc. i'd have one over the cube, just gotta get rid of the top front lights
fixed
no jamie, i was walking down to the milkbar one sunday morning and there was a garage sale, saw the deer n also found out they had other stuffed shit. paid 50 bux for the lot and took them home and scared my mum with them (imagine her reaction coming home and finding a deer in her kitchen lol)
so i threw them in the garage, chucked them for sale and yeah, got a solid bite from a bloke in adelaide
still have a stuffed german shepherd if anyone wants it
same dog, less shit, got that one seperatley though
Edited by Mohsen
make sure you don't scratch the paint tho.
probably best to just borrow a heatgun or wait for a really hot day.
You still wanna buy that turbo? Just Borrow my heat gun when you pick it up
need some new wheel nuts, lost one somehow... must not have been tightened properly
but anyway.... what would suit better colour wise, red might suit the brembos.... but the 'titanium' finish ones look pretty good
http://cgi.ebay.com.au/Wheel-Lug-Nuts-Kit-...=item3cada8affd
http://cgi.ebay.com.au/Wheel-Lug-Nuts-Set-...=item3cb0d07c29
International Students.
They play about $10,000 as I recall from 1 of them who I did a course with.
Can't fail you either cuz you pay so much :D
My bro applied for Industrial Design at Monash Uni. Got letter saying, we want you but not enough places, wait till someone drops out.
Decided to go through Monash College; a private college meaning no hecs, so its full fee (loan from the college)
$20,000 for first year. Course was full of bullshit arts subjects. In order to get into Industrial Design or Architecture, you needed 80% average. Which is bullshit because how can you grade artwork. Comes down to how the fag arts teacher "feels" about your creation etc
All they "feel" is that if they keep your average below 80%, thats more money for them lol
Dropped out, before the 2nd year starts ($15000) and re-applying for the course in the new year.
what position you looking for?
Graduate program closed a couple weeks ago :D
Cadbury bought out by Kraft Foods, so you're better off having a poke around the Kraft website in terms of job vacancies.
hehe nah i was just joking :)
i saw your plans on stalkbook while i was watching the 2 r32s blazing round the track
my r32 is good
it now has a gtr sitting next to it
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
