lolol. tpg on telstra DSLAM = fail
TPG on TPG DSLAM = win
also I ripped out all the old shitty wiring in my house and laid down fresh Cat6 cable and got telstra to come change the cable from the post to my house to a new one as well before I ditched them for TPG.
result... getting 1.5Mb - 1.8Mb (megabytes, not bits) per second on torrents.
Don't bother with customer service though, it goes to Phillipines and sucks donkey balls. Also the phone is changed to a VOIP line if you switch to a TPG DSLAM, which can suck if you're dependent on that sorta shit liek with an alarm or sending faxes like a povo kent.
Not sure what all the tech geek speak meant, but I'll pretty much only get a phone line installed at the house for internet...No need for a home phone when I've got my mobile anyway...
so how would I go about getting the good TPG you speak of? House is brand new in a brand new area too, so all the cabling will be new.
was on TPG yeah did disconnect alot specially annoying when you're trying to download stuff. no not porn.
any suggestions for nice 2nd hand meshies or similar rims for bout 1k?
sif dl porn anyway. stream bish. like you need to look at the same shit twice
can depend on the housing committee that control your estate thing. mine weren't smart enough to lay any foxtel/intenet cable. im running foxtel off satellite
life without foxtel is just not living...
Foxtel is a joke these days. The whole idea of pay tv is that there's no need for ads as you're paying for them
to run it... When we first got it back in the day ads were about 10 seconds long and only advertised the next show, but these days they're advertising products and run as long as, if not longer than free to air ads.
I download every show or movie I wanna watch and watch them whenever I want, with no commercials.
Dezz what estate you in? If it's around here I can probably give u an idea on internets
The Rise in tarneit
there's a bigger picture tho dezz... the adds NEED to be there
tv shows are made to be 22 minutes long and to keep them to half hour blocks they need to fill 16 mins per hour OR run shows at all sorts of stupid times, which pisses people off more than the adds do :rolleyes:
they also fill up slots with little shorts, but they get boring and annoying as they have to be repeated
the idea of pay tv is that you pay for more chanels and dedicated channels, not paying so you dont have ads :blink:
also nowdays on fox, 90% of the adds are for other shows on fox, and if i wanna watch it i just hit the record button and it will be there in my planner waiting for me :P
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
