BMW M3's are like the holden commodores here.
now you know. lol anyone who goes on holiday to europe knows that BMW drivers are the silvia drivers of the EU.
Found some white halogens at a place near me.
4800K for $30
http://cgi.ebay.com.au/4800K-Super-Bright-...=item1e5fd087c4
or
5000K Philips ones for $90 (pretty sure they were like 150 or something at Autobarn)
http://cgi.ebay.com.au/PHILIPS-DiamondVisi...=item1e5fc4b106
Can you get them cheaper Shan?
Edited by jezza boii
Need your help Funky!!
My rims are in Melbourne but have been Quaranteened or at Customs, WTF do I do now? Do I have to pay to get them? I'm waiting on UPS to call me.... f**kers!?&;&!?!!!
guy i used to work with had something similar. if they ship it with something that needs extensive checks they go over everything in that container with a fine toothed comb...slowly. he waited 3 months cuz his parts he ordered got shipped with a load of turbos/engine parts etc.
worse was when my uncle was waiting to take delivery of his 1953 chev...because the cars came from america they were of course shipped over with guns of some description just left in them. so again...comb. no he didnt get to keep the weapons obviously :thumbsup: but i have heard the longer the container sits at customs theres a cost associated with that that the recipients might have to pay? thats what happened to my uncle and his mates.
holy shiet. Went for a walk outside my Mayfair, London Hotel.
R8's, AMG 4wd with saudi plates, aston martins, pagani zondas, ferraris, lambos, bentleighs, rolls royce and a Bugatti Veyron!
Game over.
The Bugatti was friggen unbelieveable. What recession?
Well mayfair IS the most expensive on the monopoly board...
+1
Lighty tuned = 10sec 1/4...
I call bs on that. Don't doubt they are quick, but read the motor tuner tests.. none of them got near 10s
Still rather an sl55 though, 'charged motor and ready for roof down funtimes :(
are s15 and r34 exhausts interchangeable or similar at all?
only muffler back :(
UPS will clear it for you, but expect to get shafted with the bill. If they need to do full customs clearance cos it came in as an LCL, can be up to $700. If it's just air shipment customs clearance it'll be about $160.
Guest
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
