Yeah I know, he's kinda like the jokerdeviant of the D1 world in Japan :P
he's also tsuchiya's whipping boy. sold out when kazama and orido etc all told the old man to jam it.
got a kid comin to buy the 32 as is on thursday for 7k.
one car down... hopefully. 2 to go.
nice, if he starts tire kicking do you get to ban him from your street? and if he starts getting all up in your grills, can you edit his words to say something totally different?
LOL
just got off his P's. used to drive an integra.
he's got a hookup for paint and panel, so he's happy to fix it up.
Told him the price would be goin up if he fucks around cos I'm in no rush to sell it and don't care if he takes it or not. Basically convinced him that I was doin him a favour :P
Yeah, I think the General concensus is that if you let them drive it under the "You break it, you buy it" rule, you will usually be fine.
Anyhow, you'll know as soon as he rocks up wether he is suspect or not...just carry a breaker bar in the back pocket.
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
