Why do you want a big wing?
cos im a sick kent
@al33x
You used to see those VIP euro's everywhere. Now they're all gone. :/
Yeah, we had the rain a good 20-30 minutes ago.
yeh had that car 2.5-3 years ago, at the time was only 1 other euro gettin around like that a black one hardly anyone did them up at that stage
lol if you want a "vip" style car why not just get one thats vip from factory? why spend money turning an ordinary jap family car into a vip wannabe? ghey.
btw Alex did you sell that accord to a guy called mark?
nah man i traded it in, got raped of course thanks lexus :down:
i need your clothes, your boots and your motorcycle
you forgot to say please
Terminator doesn't say please.
how the fk did this shit get 50000 + hits
Lol man i saw it shortly after it came out.. 4500 views.... went to my mates that night and showed him.. boom 50k!
Christmas coming really soon, then we gonna have good afternoon
:laugh: so bad it's funny
lol I actually haven't - I've been told by 100's of people i should
I have enough series to watch ATM that i can barely keep up with :S
No idea why you won't pound that brunette. Creepy glee guy. :P
A bit off topic, but has anyone flown on Air Asia before?
Just booked some cheap flights to Europe. Heard from a few people that they're a pretty good low budget airline. Anyone here had any experience with them?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
