some people may find this stupid but if i were you id go for the gtst and only because it has airbags. i love the r32 gtr but i wouldnt want one as a daily because they dont come with airbags. so in conclusion get a r34 gtr lol. but im serious about the airbags part.
lol doooo eeeeet
LOL, Better not to park next to each other!
If I were to get 33 GTST, most likely I'll end up with series 1 which doesn't have airbag.
I'd better do some quotes on insurance and decide from there...
Hamish,
Yeah, found some cheapies...
One of them is maroon like yours, I immedately thought whether should I copy you or not.
Mohsen, take couple and decide when you arrive the river?
5 people in the car, not much room for tools
ill take the mid sized one
gl with the gts4, should sell quick, really good price
5 people going to fishing, for fish or?
Thanks and the dude's keen so will find out later.
Who buys a sports car for the airbags?
Scott's weak either go gtr or dont bother with a skyline.
are you serious? when we had a cement truck decide to go straight through a stop sign we hit him at about 90km/h and if we didnt have those airbags my dad and little brother wouldn't be here today so id prefer to have a car with airbags than none because anything can happen when your driving.
fair enough dude its just probably the last thing on my mind when im looking at cars to buy. gimme your gtr and get a volvo :P
haha, i think ill pass on that, my cars fast and has airbags so im happy for now :)
good news
sparky did all the work
did it for good price
did some extra stuff
it all works
bad news
cisco switch is toast
forgot to isolate that plug and the power going on/off a few times has nuked it
doh!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
