fkn weapon awesome value there is a 335i e93 (hardtop convetible) for 77k with 26ks on it in bendigo premium selection bmw i was looking at in but meh.. dont really wana tip 20k out of my pocket to upgrade
hmmm i know i could get one but not interested in convertible, i think im the same as you i could stretch my pocket out a bit more and get it but i think i might just wait a while.
IS300 only came in 6 speed auto, but has the 3.0 in it.
IS200 manual + auto, only 2.0 6cyl
Should get this one
http://www.carsales....=1011&keywords=
Black and dumped. :D
it has the optioned GPS too.
Edited by NguyenIMPROVED
Should get this one
sif that hasnt even got leather or sunroof :/
coulda sworn i seen one for sale a while ago with a 1/2jz cant remember which it was. would be a sweet luxo sleeper
335i are really fast when you flash the ecu.
Rode in one, I was blown away, 300rwkw with just a reflash.
Early model coupe are going for same money as E46 M3 now.
i f**king hate people
sitting in the car waiting for mum to get back, lady pulls up in a shiny new accord, parks alright gets out, trips and slams her hand on my bonnet/front right quarter WITH THE KEYS IN HER HAND AND DRAGS HERSELF UP.
WHAT THE f**k.
fkn women
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
