anyone know why my HICAS light is constantly on ?
i understand its something to do with the diff, but the previous owner tells me its stayed on ever since the car was lowered.
help appreciated
Edited by GTEES
Go for a walk?
considered that. yeah nah...
help appreciated
something unplugged?
Will they not provide a quality service if he doesn't mention pat with the R32?
always get quality service, but name-dropping could help in discounts or extras, and if anything goes wrong (not saying there will) I'll be on their back as well as it makes me look bad :)
should see my 0-300 video of my R32..... in gt5
hahaha..
f**k im bored at work. 8 days till p's test
should see my real 0-200km/h video of my 458italia drive :P
Video came with warning saying dont publish online due to potential prosecution. lawls
help appreciated
do you have aftermarket steering wheel on the car? Hicas has nothing to do with Diff or lowering car.
oi carnts im back
finally dug your way out from under the last root u had? :P welcome back. where've you been?
help appreciated
maybe they replaced the hicas with a lock bar?
Guest
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
