Thinking about spray painting some parts in the interior of the skyline. Colour suggestions? The car is white, but I was thinking of a matt silver or something, don't want it to stand out too much.
one of my mates in england is currently working on converting his Motec ECU to fibreoptic, so all it has is one cable coming out of it carrying up to 256 different signals.
realistically he says he'll have 3 cables, one to the dash, one to the engine bay and another to boot/fuel delivery system. still... 3 optical cables < 11ty billion wire cables that can short out, get interference, start fires etc.
Once he's finished prototyping it, I'm so gonna get on that.
I sell fibre optic cables for a living. Good shit :)
got paid yest + christmas bonus.
just bought this:
http://www.massfloef...31e11511ec15160
EPA compliant 240z + 8.1L V8 FTMFW. Should make about 350rwkw on a streetable tune. Once the kit gets here I might look at a vortech supercharger kit and custom inlet for it. Suspension (IRS, arms etc) is coming out of the S14 I have sitting in the garage, so should make it handle like a muddabitch on rails.
bending the rules is so much fun.
RA to the muddaf*kkin D
how the f**k is it legal tho?
i'm guessing EPA compliant "stock" engine still won't = engineerable in a 240z chassis
Suspected vacuum leak, after boot, it won't idle under 4300 rpm, kinda scary...
On break now, just started her up, 2300 rpm idle and acc pedal isn't loose can't see anything obvious, will need someone to hear it to diagnose properly.
Man, r32 engine bay is smaller and crowder than r33!
yup. so cramped that i still cant work out how to get my o2 sensor out without taking the heat shields off. ah well. gives me something to do this saturday
on another note, im chatting to a girl that tried her hardest and got a 28% enter.....
  • Nope 1
i painted the dash in the evo recently cause it was all scratched from previous owner
went adark gunmetal and turned out awesome, id recommend the colour to go with white to
in the sun its got some nice silver specks in it :)
ummm your ment to take the heat shield off idiot
  • Like 1
would a vacuum leak cause the car to idle so high up? Most times a vacuum leak causes a hunting idle (around 800 - 1000rpm)
Dont know much about GTR engines so cant help :(
yeh totally its not like Christmas or anything..
  • Like 1
Guest
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
