yeah well this looks factory, but better than what the evo's came out with
it was Holts Dupli-Color
DSS703 - Charcoal Grey Metallic
I used 2 cans for the dash, and gearshift surrounds was a sorta big area
That's brilliant mate, I shall look into it in the coming days.
Nick, what part of Melbourne are you from?
i dont like being car-less
i want to atleast put a deposit on one before i sell mine
pffft i bought my car before i sold the 32..... took me 5 months extra to sell it after too
not worth the hassle
Yeah ive got a can and a half here as well if your in need anyway... i bought extra to be safe :P
Im past epping, just out of wallan.... so like 30mins from northern burbs
Aah yes, I know the area well, I'm just working in Kilmore atm which isn't too far from Wallan.
Thanks for the offer buddy, might take you up on it haha How much were the cans?
driving the 33 through?
umm they were like $12 each, but if you want you can use them man... ive done what i need to with them
Hey mayne, there are some good dori-dori / hooligan roads out that way!
haha just watch the piggy's they after speeders :P
Nah, i'm usually in the ol' man's truck. Leave the '33 at home.
I would feel bad taking them, plus you might need them in future for touch ups etc. Many thanks for the offer though, my friend : )
interesting... Nick let's meet up and investigate said roads
haha ok, ill follow you though you can get caught first :P
ah yeah, im the same in old man's truck.... evo hardly gets driven during the week :P
what do you do for work?
haha no worries mate, offer there if you do need them though
Yeah, I haven't explored thoroughly as yet. Was in some newish industrial estate in the work ute the other day and all I could think about was ripping some Keichii Tsuchiya through the freshly laid bitumen.
Adam he's maco, he'd make you pay for them :P
baahahaha
I'm just doing some labouring for the old man atm until I decide what I want to do with my life lol. He's a painter / decorator. U?
Hahaha ill come again one night in next few weeks... we gotta play roulette though, better than shitty pokies
haha roulette sucks, i lose so much on it :P
baahahaha
haha im not that tight :P
ah yeah, well long as you have work
im a stonemason with my dad, doing all the tombstones at the cemeteries etc
RA to the muddaf*kkin D
how the f**k is it legal tho?
i'm guessing EPA compliant "stock" engine still won't = engineerable in a 240z chassis
engine is 1973, car is 1972. So they only have to meet EPA standards from that year. EFI and suspension conversion is outside ADR requirements. I can run a straight pipe and still be legal. Think I'll truck muffler it tho. Might be a tad louder than the 96db I'm allowed. Engine is heavy as f**k tho, and car will be light as. Super fun sideways times. Engineering is $200 for that year car :D
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
