RA to the muddaf*kkin D
how the f**k is it legal tho?
i'm guessing EPA compliant "stock" engine still won't = engineerable in a 240z chassis
gimme ride when it gets here kthnx
yeah i have.. but it's just like every other white r33 out there (like yours haha)... it's quick but i want it to look better.
thinking stealth wing and coilovers should keep me happy for a while
carbon. nuff sed
paint it orange
nearly lost my shit at that one
car bra any good for temp use on the car when driving on the freeway.....thinking of getting one made up (going to b for dirt cheap thnx to mates contacts)...just want to avoid shit hitting the intercooler and bending the vents...getting a mesh on the intercooler was an option but not much room between the front bar and the intercooler...:(
any advice for me? :D
talk to shanusr33. the full show spec white r33. he's got a custom one he uses on all the cruises. they are surprisingly exxy unless u got hookups. also be warnded: they will rape your paint if the underside surfaces aren't absolutely clean. basically a dirty car/carbra becomes sandpaper powered by the wind. also if the clasps come off, scratchy scratchy.
she'll be right though
chipping in the extra on top of insurance cover to get new wheels.
Ordering them officially tomorrow hopefully, subject to availability
yay new wheels!
... Who wants 3 advans?
Im past epping, just out of wallan.... so like 30mins from northern burbs
Incredible, I saw you today in your yellow evo pulling out of the united servo in Wallan. Would have been around 3:30-4:00? Couldn't believe it lol.
I really like the look of advan tri spokes, even though nobody else really does lol. In fact, i'm going to be spraying the ones I have in my garage this weekend.
In other news, looks like my diff has turned into a single spinner.
There's a white 33 GTR on here that has em, with nice dish and in black...that's the only time I've rated em
Yeah, unfortunately mine are in a really weak offset. But I'm going overseas soon so i'm not gonna bother buying more wheels.
Spray black maybe?
There's only two ways to make trispoke advans look good... hide the spokes by painting it black and pulling focus to the lip:
or let your nuts hang out in people's faces and show em you don't care that they're hating on trispokes by painting em a bright fluoro colour:
Guest
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
