stock airbox on with panel filter + lid = car idling badly sounds like its about to stall
stock airbox on with panel filter but no lid = car idling badly sounds like its about to stall
stock airbox on with no panel filter but with lid = car idling badly sounds like its about to stall
stock airbox on with no panel filter and no lid = idling fine
any ideas?
Edited by R-SPEC
any ideas?
Dodgy air flow meter
Idle sensor might need to be adjusted. It's idling badly when there's a restriction on airflow with restriction, but fine where there's no restriction. Start by cleaning and/or adjusting the sensor till it idles fine with the restriction. If you need to set the idle above 800RPM-ish then it's something else.
if there was an award for "the longest pipe dream" i think i would win it haha
OTOH, you might also win the prize for shortest pipe.
Hmmz i'll look into those tomorrow :thanks:
i justify driving because i fear flights..
when i came to melbourne, i boarded the plane, belted up as tight as i could, and then took a sleeping pill.. =D same thing when i went back.
weak! i be doin the ZZZZZZZZZZZZZZZUUTUTUTUTUTUTTUTUUUUUU on the way up. pisses off the person next to you quite nicely
Full licence is win. Still feel bad catching up to cars with Ps to see if they're hot though haha
me gusta
Haha I'll still do that until I'm about 30 I reckon :P P's = over 18 = legal :D
What's bad is that I still catch up to learners haha. Might have to stop that when I get my fulls..
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
