wtf are you talkin about?
lemme break it down fo ya.
interior as in the inside of your vehicle. material thats the stuff your interior will be trimmed in iirc about 100 pages back you posted a bunch of hella gay prints we all hated on where did you find them?
kapish?
dont ban me :wub:
Nah, heaps of rich kents in my area still take their car down to places like "Suds @ Mentone" to get their cars washed coz they don't have time to do it themselves.
I'm taking it one step further and going MOBILE so they don't even have to leave their own house. Ultimate convenience :) And cheap business to start up.
If it all fails then I can just use all the materials to wash my own car :P Can't really lose.
mm we use to get guys to come and wash our cars at the office, they charged to much so fkd that shit off.
I think the black looks pretty sick. Funky, got any more photos of black advans?
If anyone wants to chop my pic in photoshop, by all means go ahead as I am technologically retarded.
I bent (only slightly) the rear left tsuchia rim at Phillip Island. Needed to hit the track at winton the weekend after.
Had a set of silver tri's. Got the tyres put on, cleaned em up with acetone and 1400 grit then took to them with a matte black caliper paint from autobarnz.
Not bad for $17.
Oh and it has rear pods, got em from osaka in halam, vu painted em up.
Ugh. Hope I don't run into any huge swarms... >.>
Fkn radiator and trans cooler almost fully covered. Tough little bastards they are. Managed to bend plenty of fins on the rad. Get some flyscreen or similar and put it in front of the airholes in ur fb
Haha didn't know u lost it
sif have no license :P
tried adjusting idle with filter/lid on, best i could manage was ~600rpm with some puffing at the exhaust tips. sounded pretty ill at the start but got better as the car warmed up..
i'll change the afm aswell, see if that makes any difference "/
Rimon go primal for ya guards
Funky where did you get them interior materials from?
whats their address?
DSC%28141%29.jpgIn sydney right now. Didn't run into any locusts. Killed a few pretty good looking butterflies though. :P
50-60% shade cloth, tied on with zip ties. GOTTA LOVE ZIP TIES!
Ziptied to the tow hook thing. :P
edit
BTW, every person who's done that shade cloth thing for the front of their car. I've always realised they never show their plates, just cover it. HMM. I just cut a line where the plate was and stretched it around the plate. Lol.
Yes we're back, how have I missed this lovely forum.
Is it something wrong with me if I don't find my 270rwkw R32 GTR that exciting to drive anymore?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
