my insurance i just did online with just car, covered for 31 grand (auto came up with that) was suppose to be 3k a year, but i went the higher excess option so its only 2k a year.. (im 21)
and lol alex ^^
dw about the haters mohsen, i had a 4 door 33 on my P's was ugly as balls tho still was happy it was a skyline and at that stage i had the whole 'zomg skyline bro' thing going as well lol
im not worrying, it makes me happy, thats all that matters
also, mates calling it the annoying skyline :P
arab misus from the motherland waiting visa aproval? :P
bahahaha girl im talking to put up i <3 skylines on her status, intended for me
kunts start commenting saying they want 1, i comment and she starts going on about it
kunts mad jelly. only arabs would be jelly of an R32 LOL
lol nah man just interstate. only muztek girls like skylines :P
Do want that sound
mmmmm audi s2 shit yeah porsche engine/brakes and rare as f**k
just finished watching new top gear episode "Three Wise Men Special" crack up must watch!
she isnt muztek actually, nowhere near it. maybe sucking up haha
leigh, yeah, a skylines still a better car than many holdens or falcoons
do they know its 4 door? probably wouldnt be so jealous if they did
as far as muztek chicks are concerned a 4 door indicates that you're quite a mature gent who is taking his taxi driving quite seriously and can provide for her and all the monobrow babies she intends to pop out.
0.o
thanks bro
Negatory. 26, been comprehensively insured since 18, no claims.
$2064 per year for the Pulsar, Skyline & Cube full comp (although the Pulsar's currently under laid-up cover and the Skyline extreme limited use cover.) The Skyline makes up the majority of that premium (about $900 I think) so once that sells it'll come down significantly.
Baaahaha made my morning
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
